LSM303D temperature format
Options
‎2014-07-04 6:19 AM
Posted on July 04, 2014 at 15:19
I got good results reading accelerometer data but the temperature register is about 36 (decimal), the datasheet mentions 8LSB/°C, 36/8 = 4.5°C, this is quite cold ;) Room temp is 24°C, the other sensors located near the LSM are indicating 28°C.What is the good conversion factor?
Labels:
Accelerometers
Options
‎2016-07-13 6:09 PM
Posted on July 14, 2016 at 03:09
I see there has been no replies to your post for the past 2 years.Check out this disappointing answer by Miroslav from ST:/71915817
Options
‎2016-08-12 12:27 AM
Posted on August 12, 2016 at 09:27
Unfortunately
the temperature sensor can be used only to measure temperature variations. It isn't suitable to return absolute temperatures measures. The value represents difference respect to a reference not specified value.
Best regards
Miroslav
