LSM303AH vs ISM303DAC differences.
‎2020-10-29 6:22 AM
Hi. What are the differences between them?
INEMO-Inertial Modules
‎2020-10-30 3:13 AM
Hi @Bacteriusartnik​ ,
ok I just see you have edited the post.
LSM303AH and ISM303DAC are very similar chip: the main difference is that the ISM303DAC ha been qualified in industrial conditions, while the LSM303AH ins standard conditions.
If your application is not industrial, you can use the LSM303AH.
-Eleon
‎2020-10-29 8:43 AM
are you referring to the LSM303DLH, right?
The ISM303DAC device has in general better performances than LSM303DLH one, especially regarding:
- higher resolution for the accelerometer (sensitivity on 16 bits);
- wider magnetometer full scale;
- industrial grade qualification;
- currently available on the market.
-Eleon
‎2020-10-29 9:06 AM
Hi im referring to: https://www.st.com/resource/en/datasheet/lsm303ah.pdf
‎2020-10-30 3:13 AM
-Eleon
‎2022-05-06 4:56 AM
I have a related question: Can we use ISM303 for Tilt-compensated compasses application as well? When checking the datasheet, Tilt-compensated compasses is mentioned only in the 'Applications' of LSM303 and not in ISM303.
I was looking to ISM303 for a Tilt-compensated compass application. Can you please share your comments?
Akshay
