2024-04-24 1:30 AM
Good morning,
I work actualy with the LIS344LH accelererometer and I was informed it will not be available anymore.
Do you know any other devices that would substituate it ?
I need it for measuring the movement of a tuning fork with a resonnance frequency of 1.8kHz.
Thank you everyone :)
2024-04-24 2:41 AM
Hi @fru999 ,
I can suggest you IIS3DWB which has an ultrawide and flat frequency response range from dc to 6 kHz (±3 dB point).
Hope this helps :)
2024-04-24 2:41 AM
Hi @fru999 ,
Hope this helps :)
