2023-11-22 04:51 AM
May I kindly clarify whether MKI239A adapter is compatible with MKI109V3 motherboard?
From MKI239A's website and Unico's GUI (device selection list), it seems that it is compatible.
But from MKI109V3's "Tools&Software" page and UM2116 (Sec.3 - Supported MEMS adapter boards), MKI239A is not shown in the list...
I am a bit confused...
2023-11-22 05:01 AM
Hi @ZSong ,
I confirm you that MKI239A is compatible with MKI109V3 motherboard, you can try not to select the com port and select it later in the second page of Unico that will appear.
Let me know if this solves.
2023-11-22 05:01 AM
Hi @ZSong ,
2023-11-22 05:03 AM
This description also says that MKI239A adapter compatible with MKI109V3 Motherboard: https://www.st.com/en/evaluation-tools/steval-mki239a.html
