2012-04-24 6:38 AM
ist their any iNemo Project already ported in KEIL ? I'm searching for a solution to use the IAR Project in Keil but I always failing when i trying it by my self. with regards Sam2012-05-23 4:29 PM
Have you been able to build any of the ''plain vanilla'' STM32 example projects - eg, for a Discovery board, and/or one of the DevKits?
Perhaps it would be easier to start from there, and gradually bring-in the iNEMO bits...? It would show you how to set-up a project for Keil; and you could then compare it against the IAR stuff - might give a better idea of where you're going wrong...? Cross post:http://www.keil.com/forum/20905
