Posted on May 24, 2012 at 14:47Hi there,
I'm using an L3G4200D sensor for calculating the angle displacement
with the code below. However from the computation I get half of the real rotation
the sensor make, that is, if I rotate it of 90 degree, I measure a 45 degree rotation.
The output data rate is set a 100hz, resolution is 250dps and the BW is set at 12,5Hz.
I realized that I might loose some samples (I don't use interrupts),
but that should not be a problem when rotating at constant speed,
as I always calculate the delta from the last sample.
Any suggestion would be appreciated.
  http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L117
  while
1
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L118
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L119
   gyroscope.readGyroscopeData(x, y, z);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L120
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L121
  // Data rate is 100Hz, thus T = 0.01s
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L122
   uint64_t currentValue = util::currentCounterValue();
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L123
   uint32_t delta = currentValue - previousValue;
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L124
   timeElapsed = (
float
)delta /
1000000
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L125
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L126
   previousValue = currentValue;
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L127
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L128
  /* Convert data to dps */
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L129
  if
 ((x - x0) > kThreshold || (x - x0) < -kThreshold)
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L130
   wxz = (x - x0) *
0
.00875
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L131
  else
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L132
   wxz =
0
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L133
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L134
  if
 ((y - y0) > kThreshold || (y - y0) < -kThreshold)
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L135
   wyz = (y - y0) *
0
.00875
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L136
  else
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L137
   wyz =
0
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L138
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L139
  if
 ((z - z0) > kThreshold || (z - z0) < -kThreshold)
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L140
   wxy = (z - z0) *
0
.00875
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L141
  else
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L142
   wxy =
0
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L143
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L144
   xz += (wxz * timeElapsed);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L145
   yz += (wyz * timeElapsed);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L146
   xy += (wxy * timeElapsed);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L147
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L148
   sprintf(bufferOut,
#wxz=%+f wyz=%+f wxy=%+f xz=%+f yz=%+f xy=%+f
\n
http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L149
   wxz, wyz, wxy, xz, yz, xy);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L150
   trace(bufferOut);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L151
     http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L152
   gpioPortC.toggle(GPIO::ePin12);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L153
  /* Sensor data rate is set at 100Hz. */
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L154
  //util::delayms(1);
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L155
   http://geneva.servebeer.com/redmine/projects/opencortex-m/repository/revisions/master/entry/demos/l3g200d-i2c/main.cpp#L156
