I have a STEVAL-MKI185V1 magnetometer and I am logging data using the Unico software. When I access the log as a .txt file, I cannot seem to print the timestamp for each row of data. Does anybody know if this can be done? Thanks, Joe
JJame.16
Eleon BORLINI
Hi @JJame.16​ , the timestamp is not directly available through UNICO GUI, but you can go back to the time value starting from the ODR you set for the data output --> 1/ODR will be the basic time base. You can set the T0 according to your need. Regards
