2020-09-12 4:38 AM
This is the register values set by me for 400g and data output rate is 50z
2020-09-14 6:12 AM
Hi @NMALH ,
From an hardware point of view, can you please share some more details of your application circuit? For example, which Vdd and VddIO levels are you using? Are you correctly setting all the device pins?
From a firmware point of view, are you able to read the WHO_AM_I register? I suggest you to check if you configured the sensor accordingly to the C-examples on Github, in particular the h3lis331dl_read_data_polling.c.
/* Check device ID */
whoamI = 0;
h3lis331dl_device_id_get(&dev_ctx, &whoamI);
if ( whoamI != H3LIS331DL_ID )
while(1); /*manage here device not found */
/* Enable Block Data Update */
h3lis331dl_block_data_update_set(&dev_ctx, PROPERTY_ENABLE);
/* Set full scale */
h3lis331dl_full_scale_set(&dev_ctx, H3LIS331DL_200g);
/* Configure filtering chain */
h3lis331dl_hp_path_set(&dev_ctx, H3LIS331DL_HP_DISABLE);
/* Set Output Data Rate */
h3lis331dl_data_rate_set(&dev_ctx, H3LIS331DL_ODR_5Hz);
-Eleon
2020-09-14 6:12 AM
Hi @NMALH ,
whoamI = 0;
-Eleon
2020-09-17 1:29 AM
Dear Eleon,
Thankyou for the reply. Yes, my problem got solved. Before I was multiplying my readings with wrong value of sensitivity.
