2020-07-24 2:58 AM
HI everyone,
I have this error message when I compile my main program with eclipse ... I'm using a P Nucleo 53L0A1 .. someone can tell me what's happening because I really don't understand
error message =>
Open On-Chip Debugger 0.10.0+dev-00021-g524e8c8 (2019-04-12-08:48)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
C:/Ac6/SystemWorkbench/plugins/fr.ac6.mcu.debug_2.5.0.201904120827/resources/openocd/scripts/st_board/nucleo_l476rg.cfg:15: Error: Can't find target/stm32l4.cfg
in procedure 'script'
at file "embedded:startup.tcl", line 60
at file "C:/Ac6/SystemWorkbench/plugins/fr.ac6.mcu.debug_2.5.0.201904120827/resources/openocd/scripts/st_board/nucleo_l476rg.cfg", line 15
2020-07-24 5:01 AM
I would use the example code provided in X-CUBE-53L0A1 to check if your AC6 IDE is working and base on the example code structure to develop your own code.
Thanks,
Julien
