2015-11-03 01:27 AM
I'm planning to get 3200Hz data rates for ADXL345 sensor with Nucleo board. The SPI speed is 5MHz. And i initialized exactly as per the data sheet.the initialization process is as below:accelerometer.setPowerControl(0x00);accelerometer.setDataFormatControl(0x0B);accelerometer.setDataRate(ADXL345_3200HZ);accelerometer.setPowerControl(0x08);Here I'm using high baudrate.Suggestions would be appreciated. Thank you.
