2024-10-30 2:28 AM - last edited on 2024-10-30 3:28 AM by Andrew Neil
Good morning,
I'm using the STEVAL-MKI109V3 board associated with the STEVAL-MKI201V2.
Is there a source code for using the STEVAL-MKI201V2 accelerometer with the STEVAL-MKI109V3 board?
Otherwise there are examples of using the STEVAL-MKI201V2 with other microsprocessors?
Thank you.
Best regards.
Gb2.
2024-10-30 2:50 AM
@Gb2 wrote:Is there a source code
Look on the 'Tools & Software' tabs on the Product Pages for the boards and the sensor itself; eg,
https://www.st.com/en/evaluation-tools/steval-mki109v3.html#tools-software
https://www.st.com/en/mems-and-sensors/lsm6dso32x.html#tools-software
@Gb2 wrote:using with other microsprocessors?
Do you mean microcontrollers?
C-Driver-MEMS "Standard C platform-independent drivers for MEMS motion and environmental sensors" is probably best for that:
2024-10-30 2:50 AM
2024-10-30 2:54 AM
@Gb2 Also, you obviously have a typo, as there is no STEVAL-MKI201V2.
2024-10-30 3:15 AM
Peter BENSCH exactly! It is STEVAL-MKI210V2K.
