2018-09-14 3:45 AM
Require some basic knowledge to use LIS3DHTR https://store.ncd.io/product/lis3dhtr-3-axis-accelerometer-digital-output-motion-sensor-i2c-mini-module/ to work with arduino and make the TAP detection solution but to make it work. As beginner in this, I still need to know about theoretical point which will help to implement with code. Any suggestion to make it work will be very helpful
2018-09-14 4:13 AM
You can read chapter 8 in application note AN3308.
