2024-03-17 9:14 PM
hello Good Morning,
i'm working on asm330lhh imu sensor, i want to get output in angle from raw value. please give suggetion and if you source code of imu sensor so share here.
2024-03-19 7:18 AM
Hi @semiconductor_user ,
You can follow our PID examples on github.
Let me know if this helps.
2024-03-21 5:41 AM
but there i can't get solution, so if you have formulas and logic for convert raw value into angle please share here.
2024-03-26 3:44 AM
You can refer to the Datasheet.
You need to multiply the raw data by the sensitivity depending on your FS:
