After a long poweroff I can`t read ASM330LHH_WHO_AM_I (0xF0) register correctly.
SPere.4
I`m usung STEVAL-MKI193V1 board + STM32f103c8.
After init, It shows me sometimes 0x48 0x4C 0x54, 0x56 but it should be 0x6B.
But sometimes after debugging multiple reboots, step by step executions, I manage to see the number 0x6b and everything works correctly, looks like a heisenbug.
My commection scheme:
VDD  - +3.3
VDDIO - +3.3
GND  - GND
NSS  - SPI2_NSS (pa12)
SCK  - SPI2_SCK (pa13)
SDO  - SPI2_MISO (pa14)
SDA  - SPI2_MOSI (pa15)
INT2 - GND
INT1 - GND
uint16_t SPI_rx(uint8_t address) {
    uint8_t ret = 0;
    address = 0x80 | address;
    GPIO_ResetBits(SPI2_NSS, SPI2_PIN_CS);
    while (!SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE));
    SPI_I2S_SendData(SPI2, address);
    while (!SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE));
    SPI_I2S_ReceiveData(SPI2);
    SPI_I2S_SendData(SPI2, 0x00); //send null for recieve data
    ret = SPI_I2S_ReceiveData(SPI2);
    GPIO_SetBits(SPI2_NSS, SPI2_PIN_CS);
    return ret;
/*call function*/
id = SPI_rx(ASM330LHH_WHO_AM_I);
2 REPLIES 2
AG.8
Hi @Akellaerepelkin​ ,
note that the WHO_AM_I register is 0x0F instead of 0xF0 as reported by you.
I believe however this is not the problem here. Are the SPI lines stable, from the oscilloscope? Maybe it's only a matter of delays, since you are able to obtain the correct WHO_AM_I in a step-by-step debug.
Can you try the same procedure leaving the INTx pin floating?
AG
Made more stable:
  1. Used different wires (shorter). Because I think electromagnetic interference takes place.
  2. Also I noticed that good working depends of right poweron - sometimes I need to reeboot it several times. I thint I need to make MEMS poweron with some delay.
  3. As you mentioned - made INTx pin floating.
  4. No syncronization in MCU debug-mode, there was something similar: https://community.st.com/s/question/0D53W000003vhUNSAY/h3lis331dl-id-problem
Yes, you`re right - 0x0F instead of 0xF0, otherwise nothing would work. It is mistake in text. I used official library.
Thanks.
