ST87M01
JuanMarGo
I'm trying to develop a multiprotocol board with Dual Stack wM-Bus + NB-IOT. I found this link:
https://www.st.com/en/wireless-connectivity/nb-iot-products.html
So the ST87M01 module is capable of it.
I have the next questions:
1) The module is sold with the firmware (dual stack) flashed ?
2) The module need extra hardware? It is a noise filter or something, or it just need a STM32L5 as a host?
3) Where can I find documentation about how to control the ST87M01 module from the host? An AT command list or something.
Thanks!
Correct, there is no dual stack built-in.
8 REPLIES 8
I read every document and didn't find nothing about question 1) and 2).
About the 3) question Section 1.2 "Reference documents" on page 2 of the manual lists "ST87MXX_UM_AT commands description" as document number (2). This indicates that a separate document exists which describes the AT commands for the ST87M01 module family, BUT I can't find it.
@JuanMarGo On the overview page it is expressed somewhat ambiguously: ‘suitable for multi-protocol such as wM-Bus as fallback solution’ means that it can be used INSTEAD of wM-Bus if necessary. It therefore does not contain a wM-Bus stack.
Otherwise, all public information can be found on the product's website. For more detailed and additional documents, please contact your local distributor or the local office of STMicroelectronics.
Hope that helps?
/Peter
Hmmm ... yes it is:
I think that's rather misleading.
I guess what they meant was, "can be used in conjunction with an wM-Bus device to provide an NB-IoT fallback" ?
Any chance to get this corrected?
JuanMarGo
Resuming, the chip has not dual stack inside.
@Andrew Neil Of course, there is always a chance. Let's see how quickly the web team responds.
@Lina_DABASINSKAITE Could you please pass on Andrew's suggestion?
Hi there,
Thanks for brining this up, @Andrew Neil  and @Peter BENSCH . I shared with a responsible team for a review.
Lina
