2024-05-06 3:40 AM
Are there plans for supporting the new ST 4G NB=IOT modem ST87M01 in the X-CUVE_CELLULAR software stack?
Thanks, Hans.
2026-02-04 7:42 AM
Hello Hans,
not for now. The method to build your application with ST87M01 module is :
1) to start with cubeMX and configure the BSP of you STM32,
2) then downloading the EC-Lib package on ST87M01 web page and integrating it on top of you BSP,
3) then developing you r main application on top.
Please be aware that we have added a project example based on U5 that has been built the way I describe above.
regards,
Hervé
2026-02-04 7:42 AM
Hello Hans,
regards,
Hervé
