SPWF04 HTTP POST Problem
Dmytro Medvid
Posted on January 09, 2018 at 14:30
Hello, everybody.
I want to use HTTP client mode. I should send the next message:
api/Tokens?username=test&password=123456789&serialnumber=123456789
to the server:
https://messagebus.example.com
and get the response.
I try to make next:
AT+S.HTTPPOST=messagebus.example.com,/api/Tokens,,,,,Get.txt,Send.txt
In send file i have
username=
test
&password=
123456789
&serialnumber=
123456789
but, server give me Error 404 answer. I think, there is a problem in my AT+S.HTTPOST mesage.
4 REPLIES 4
Gerardo GALLUCCI
Posted on January 09, 2018 at 16:48
Probably I'm using wrong URL...
I get 'DNS error' (502 Bad Gateway) with the browser, and 'Http Client Error:0' with the module. Is it correct 'messagebus.example.com'?
Posted on January 09, 2018 at 19:28
No, it is just for example.
Posted on January 10, 2018 at 11:28
Don't know how to help you...
Try to bypass the send.txt file, and directly put form content into <path&query> parameter. Same result?
AT+S.HTTPPOST=messagebus.example.com,/api/Tokens?
Posted on January 11, 2018 at 17:51
YES, it works!!
Thanks))
