SPWF01Sx in WiFi Direct Mode
hal
Posted on August 06, 2015 at 18:01
I am trying to connect to SPWF01SA using WiFi Direct.  Is this supported yet and is there a guideline for how to set it up in the configuration?  I have seen the keywords ''AhHoc/WiFi Direct Mode'' in ST presentations but there is little to be found on how to do this.
With thanks,
Hal.
1 REPLY 1
Posted on August 07, 2015 at 08:31
Hi Hal,
SPWF01S supports STA, miniAP, and IBSS (ad-hoc). WiFi-Direct is not currently supported.
If you need to avoid an AP, you can use IBSS; if you need WiFi-Direct (smartphone interoperability, et al.), SPWF01S is not suitable.
ciao
jerry
