2015-08-06 09:01 AM
I am trying to connect to SPWF01SA using WiFi Direct. Is this supported yet and is there a guideline for how to set it up in the configuration? I have seen the keywords ''AhHoc/WiFi Direct Mode'' in ST presentations but there is little to be found on how to do this. With thanks, Hal.2015-08-06 11:31 PM
Hi Hal,
SPWF01S supports STA, miniAP, and IBSS (ad-hoc). WiFi-Direct is not currently supported.If you need to avoid an AP, you can use IBSS; if you need WiFi-Direct (smartphone interoperability, et al.), SPWF01S is not suitable.ciaojerry
