SPWF01SA NTP client
Manfred Dietrich
Posted on January 12, 2017 at 13:21
Is there a sample implementation of a NTP client to get the time from a timeserver?
I use the SPWF01SA together with a STM32F401.
BR,
Manfred
#spwf01-ntp
Posted on January 12, 2017 at 19:58
Hi Manfred,
if SimpleNTP is enough, you can open a simple UDP socket  (AT+S.SOCKON) and write (AT+S.SOCKW) a 48 byte requesto to server. Than expect a 48 byte reply, and read (AT+S.SOCKR) it.
http://ceng393.cankaya.edu.tr/uploads/files/file/ntp_project-1.pdf
 a simple flow.
Hi Manfred,
 a simple flow.
Posted on January 12, 2017 at 20:09
Hi Gerardo,
SimpleNTP is accurate enough.
Thanks for your quick answer.
Manfred
