2015-07-27 5:03 AM
2015-07-27 5:21 AM
Please update your FW.Are you sure your AP is set with WPA2 key? Scan command gives you ''WPA'', not ''WPA2''...Regardsj2015-07-27 5:41 AM
Hello Gerado,
yes, you are right Key is WPA not WPA2. Is there any difference, in AT Commands ? Or just FW upgrade will fix it ? Best regards, Alex2015-07-27 5:48 AM
I don't know if it fix the problem, but updating the FW we'll be able to get the deauthentication reason code after WIND:40.
It's a better starting point...j2015-07-27 6:44 AM
I've tested it now with an other Ap.
The module ony has problems with WPA. WPA2 is working fine Thanks for your help.
