[solved]fastest communication
hector
Posted on April 20, 2015 at 11:29
I'm trying to achieve a communication between two wifi devices through a SPWFO1SA.11 , and I want to achieve the highest possible bite rate. My questions are then:
-Can I use the mentioned SPI port to perform the AT commands?
-Can I use the GPIO to transmit data to the SPWF to create a file for instance?
Best regards,
Hector
#spi-error
12 REPLIES 12
ccamacho
Posted on June 30, 2015 at 15:01
Hi, thanks for your answer.
I bought the modules at mouser.com.
Can you explain me or give me some tutorial to update the FW?
Thanks a lot.
Posted on June 30, 2015 at 15:25
Download complete package from ST website: http://www.st.com/web/en/catalog/tools/PF260799
You can follow the tutorial inside it, about serial and/or OTA update.
ccamacho
Posted on July 01, 2015 at 15:10
Than you, I'll try to do this.
