Sensor Tile, BLE example application only works on the Cradle, but not cradle expansion board?
Sam Ho
I am reading the user guide, quick question, does the ble example only works on the cradle board, but not the cradle expansion board. page 9 figure 6. https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/57/ae/1e/58/ed/6c/46/47/DM00311355/files/DM00311355.pdf/jcr:content/translations/en.DM00311355.pdf
Many thanks
Sam
Winfred LU
Hi Sam,
It shall work both with Cradle and Cradle expansion.
But for applications requiring components only available in Cradle (such as HTS221) will not work with Cradle expansion.
Best Regards,
Winfred
Sam Ho
Hi Winfred,
Thanks for your reply,
I believe i have the first version of the SensoTile kit, (the plastic case to hold the cradle is black) I tried the bluetooth example on the cradle expansion. doesnt seems to work. Bought a new sensor tile, works straight on the cradle expansion. So maybe I have a hardware problem on the earlier version or something else...
Sam
