S2-LP and mesh stack
BMoha.19
Is s2-lp RF module supports mesh? If yes, where can'i found mesh stack and how it can be used?
Is below application note describe how can'i configure s2-lp module to work on mesh network? https://my.st.com/resource/en/design_tip/dm00567382.pdf
Thanks in advance.
6 REPLIES 6
Winfred LU
Hi Nasramine,
Please take a look at X-Cube-Sub1,
which includes diddleware library with Contiki OS and Contiki 6LoWPAN protocol stack
with ability of mesh networking.
https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-subg1.license=1553344373402.product=X-CUBE-SUBG1.version=3.1.0.html
Thank you.
Best Regards,
Winfred
BMoha.19
Thanks a lot for your Answer.
In X-Cube-Sub1 i didn't found a complete example with mesh networking. Examples under "X-CUBE-SUBG1\en.x-cube-subg1_firmware\STM32CubeExpansion_SUBG1_V3.1.0\Projects\Multi\Applications\Contiki" didn't describe how to create mesh network
I saw that we have mesh api such as mesh_open, mesh_send..., should these APIs be called just after Stack_6LoWPAN_Init in each node?
Thanks a lot in advance.
Winfred LU
Hi Nasramine,
For Contiki's mesh samples, please refer to Contiki's document
http://contiki.sourceforge.net/docs/2.6/a00011.html
Best Regards,
Winfred
BMoha.19
Hi Winfred,
Thanks for Contiki's mesh samples.
All mesh APIs (mesh_open, mesh_send...) should be called after calling API Stack_6LoWPAN_Init (otherwise S2_LP transceiver will not be started and mesh cannot be established)?
Mesh code deployed in each node will be something like this:
int main()
HAL_Init();
SystemClock_Config();
HAL_EnableDBGStopMode();
MX_GPIO_Init();
USARTConfig();
#if MCU_LOW_POWER
if (USER_CLOCK_FREQUENCY != DEFAULT_CLOCK_FREQUENCY) {
   HAL_RCC_DeInit();
   LP_sysclk_config(USER_CLOCK_FREQUENCY);
   MX_GPIO_Init();
   HAL_UART_DeInit(&UartHandle);
   USARTConfig();
#endif /*MCU_LOW_POWER*/
/* Initialize LEDs */
BSP_LED_Init(LED2);
RadioShieldLedInit(RADIO_SHIELD_LED);
BSP_PB_Init(BUTTON_USER, BUTTON_MODE_EXTI);
/* Initialize RTC */
RTC_Config();
RTC_TimeStampConfig();
_print_fw_info();
Stack_6LoWPAN_Init();
mesh_open(&mesh, 132, &callbacks);
Thanks to correct me if i'm wrong
Best Regard,
Amine
BMoha.19
Hi Winfred,
Any news please?
Best Regard,
Amine
Winfred LU
Hi Amine,
You've got the entry.
Please try to replicate Contiki mesh example.
Best Regards,
Winfred
