2024-07-07 11:36 PM
I'm a novice in STM32WB and BLE mesh. I have started using the "BLE_MeshLightingPRFNode" example test with the "ST BLE MESH" APP. I want to use the "vendor model" to transfer the segmented and unsegmented packets in BLE mesh network by a host node that can be a proxy node or gateway node.
Although I successfully used the "ST BLE MESH" APP to communicate with the node(STM32WB5MM-DK) running "BLE_MeshLightingPRFNode" by the "vendor model". But I need to know how to use the provisioning & proxy service to communicate with mesh and its interaction.
There are the questions below.
2024-07-24 6:34 AM
Hello @Cooper_WJH
I suggest you follow the recommendations of the AN5292. It should be helpful for you.
Best Regards.
STTwo-32
