2022-05-23 8:48 AM
Is they have any PCB antenna design (.dxf file or other) which i can use with BlueNRG-2N ?
Tahnk you,
Sincerely.
2022-05-30 12:57 PM
Hi @malarab ,
FYI, STEVAL-IDB012V1 (BlueNRG-LPS evaluation board ) is using PCB antenna. You may reuse it for BlueNRG-2N - of course matching circuitry and balun must be adapted..
Gerbers/layout of this evaluation board are available for download here
Now, for sure and depending of available space on your PCB, multiple design can be considered. BTW, a lot of 2,4GHz PCB antenna design are available on the web - there is no specificities for BlueNRG-2N
Sebastien.
2022-06-09 5:11 AM
thank you Sebastian,
i am looking for an antenna design file to import it directly in my project, and i cannot find one online.
do you have any suggestion?
thanks again,
