Is the wireless m-bus stack provided by ST also available as source code?
Roman Jasmann
in the SPIRIT1 SDK (STSW-CONNECT009), ST provides the wireless m-Bus stack as a library. Is it possible to get the source code of the stack?
1 REPLY 1
NBen
Did you have an up-date for your issue? I am facing the same problem, and I couldn't find anything useful. (I am using the STEVAL-FKI868V2.
