2021-11-29 11:56 PM
Dear Sir/Madam,
This mail is regarding to know the status(lifecycle) of the component. We wanted to know the part status of these components like whether it is active or obsolete,
and wanted to know whether it is RoHS complaint ,if in case it is obsolete means could you please suggest us an alternative part number for this.
Please find the part details below.
74V1G14CTR Ic, Digital, Sgl Inverter, Schmitt Trig
Kindly revert back to us ASAP.
2021-11-30 12:09 AM
Welcome, @SGoud.1, to the community!
the 74V1G14CTR was already discontinued several years ago.
ST does not offer a replacement, nor are there any documents, e.g. RoHS information.
Good luck finding an alternative!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
2021-11-30 12:09 AM
/Peter
2021-11-30 5:06 AM
2021-11-30 6:25 AM
You can always find the status on the website of the respective component, if it has not already been discontinued and is therefore no longer visible. The status of the BAT54 can be found here, indicated by the small sign to the right of the device name, here: ACTIVE = Product is in volume production.
One last request: this is a forum for exchanging ideas and answering technical questions that do not really include questions about cancellation and availability. The latter can best be answered by your preferred distributor, who can be found under Contacts.
/Peter
