2020-12-01 06:08 AM
2020-12-07 03:45 AM
2020-12-07 04:53 AM
Hi Ihmm,
No it is not.
After this registration, did you try to login again ? Did it work or not ?
Best Regards,
Ons.
2020-12-07 05:00 AM
2020-12-07 05:12 AM
Hi Ihmm,
It is really a bizarre behavior. The link "Already registered" should work. I tried with several email addresses and it works perfectly.
Best Regards,
Ons.
2020-12-07 05:20 AM
2020-12-07 05:25 AM
Hi Ihmm,
Very good. So, I suggest that there was a problem with the email address added at the beginning (maybe a miss-typing or something like that) !
In case the problem is solved, Can you please mark the question as answered and choose the best answer for you?
Best Regards,
Ons.
