How to use S2LP libraries provided by ST as a beginner with no prior experience
2023-06-07 10:27 PM
Hello, I am a beginner trying to make a project with stm32 nucleo l452re and s2lp on steval fki868v2. I downloaded the s2lp library which has a drivers folder (with subfolders BSP,S2LP Library, MCU, S2LP_Middleware,Utils).
When I add this to the stm32cube Ide project under drivers and give include paths in project properties and then try to use some functions of the library, or replicate basicgeneric.c example, I get a cascade of compiler errors.
Pls help me out.
A sample project link as to how all the folders are to be included without errors in compilation and what paths to give to compiler would be extremely helpful.
Low Power RF Solutions
2024-08-06 1:06 AM
Hi there I am also struggeing with this device. First you should install in CubeIDE the X-Cube-SUBG2 in the Middleware and Software Tab. If you choose this in your STM reooisitory a package "X-CUBE-SUBG2" is downloaded. In the subfolder 5.0.0/Documentation you will find a pdf "STMicroelectronics.X-CUBE-SUBG2_GettingStarted.pdf" which explains how to set up a project. Further you will find under Projects/Nucleo-.. StmCubeIde Project ready to compile.
