How to use S2-LP with contiki?
Gz
Hi All;
I would like to know how to use S2-LP with contiki. I saw border-router, serial sniffer, udp client and udp server are example code. I don't saw sensor node to example code. Could you please advice me about how to build sensor node project with STM32CubeIDE?
Best regards.
21 REPLIES 21
MGREL
All RPL related parameters, like DAG lifetime, can be found in
Middlewares/Third_Party/Contiki-NG/os/net/routing/rpl-lite/rpl-conf.h
you can edit this file or, better, define the "*_CONF_*" version of the parameters in your project-conf.h
Hello @MGREL​ ;
Thank you for your reply.
I can edit lifetime. Could you please tell me for parameter( On border router) decode from client?
Thank you,
Best regards.
