2020-10-01 08:21 AM
I am using the BLUENRG-M2SP ble chip set , i created the 2 services ,there services are Primary Services 1. first service has the 3 characteristics and Second services has the 5 characteristics , if i add third services , i am getting Lack of Memory Error , Kindly help me out
how much memory utilized each characteristics. and service ,
2020-10-14 08:27 PM
After installing BlueNRG-1_2 DK package, an utility called BlueNRG-X Radio Initialization Parameters Wizard will be available for your easily generating config file, including the reserved memory size for your customized service and characteristics.
Please refer to DK package:
and the document located at:
file:///C:/Program%20Files%20(x86)/STMicroelectronics/BlueNRG-1_2%20DK%203.2.1/Docs/BLE_Radio_Parameters_Wizard/BLE_Radio_Parameters_Wizard.html
2020-10-16 06:37 AM
Thanks for hint , i will go through link.
