2018-08-22 09:31 AM
Hello. I have STEVAL-IDB008V2 and I have 1 service with 5 characteristics for BLE. I use SensorDemo program coming with STSW-BLUENRG1-DK for tests. Problem is that I can not add more services and characteristics because Out of Memory error is received. I need to add 7 services with 7 characteristics each for my application. For example with ESP 32 this is not a problem. Is there any option that could be changed to achieve these requirements or just these is the potential of the BlueNRG 2? Thanks in advance to everyone that could help.
Best regards,
Deniz
2018-08-29 01:52 AM
What is your configuration of BlueNRG?
Is it processing Bluetooth itself or is used in Network Processor configuration?
Piotr
2021-03-17 12:20 AM
Sorry for the late answer I had troubles to find this article that I post. Now so much time later everything is OK. I made my project years ago. But on your question I used it processing Bluetooth itself. Thank you for your kindness. And sorry again. The topic could be deleted.
Best regards,
Deniz
