How can connect to my S2-LP register with S2-LP DK tools
‎2019-05-19 4:56 AM
Hi
I need to export configuration from my S2-LP soldered on my board. I succeed to export S2-LP in eval board using S2-LP DK tools, but, i can't display S2-LP register soldered on my borad (can't connect to my board with S2-LP DK tools). Is there a specific configuration for that?
Thanks in advance.
Low Power RF Solutions
‎2019-05-19 7:52 PM
Hi nasramine,
Please check SPI connection and SDN.
During start-up, SDN must be kept high for at least 1 ms.
Please refer to datasheet, Figure 7:
https://www.st.com/resource/en/datasheet/s2-lp.pdf
Best Regards,
Winfred
‎2019-05-22 3:26 AM
Hi Winfred,
Thanks for your quick answer.
During start-up, SDN was kept high for 1,485 ms as mentioned on below measurement:
When i try to connect with S2-LP DK tools to my board (based on STM32L0xx) i have below problem:
Any proposal for the problem please?
Best Regards,
Mohamed Amine
‎2019-05-22 11:27 PM
Hi Mohamed,
Could you please firstly check if SPI reading 1byte from S2LP register works?
Best Regards,
Winfred
‎2019-05-22 11:36 PM
Hi Winifred,
My firmware is already sending data to another node with S2LP. I have only a problem with S2LP DK tools.
Be Regards
Mohamed Amine
‎2019-05-22 11:53 PM
Hi Mohamed,
Could you try connect the Virtual COM port and check the output for the followed commands:
- SdkEvalSdn 1
- SkdEvalSdn 0
- SdkEvalSpiReadRegisters 0xf0 2
- fwVersion
- SdkEvalGetVersion
- S2LPGetVersion
- EepromReadPage 0 0 1
- EepromReadPage 0 0 32
Best Regards,
Winfred
‎2019-05-23 3:47 AM
Hi Winfred,
With eval board NUCLEO-L152RE i can run commands as below (after fashing CLI binary with S2-LP DK tools):
but when i used my customer board (based on stm32l0), commands cannot be runned. I think, it's related to CLI binary.
Can you please share with me source code of CLI?
Best Regards,
Mohamed Amine.
‎2019-05-24 12:52 AM
Hi Mohamed,
Please use STM32L053 for the board and flash S2LP_CLI_NUCLEO_L0.bin instead.
Regarding to the source code, sorry that currently there is no plan to share it publicly.
Best Regards,
Winfred
