Help to interfce X-NUCLEO-NFC01A1 with BlueNRG2
AKuma.2074
I m trying to interface X-NUCLEO-NFC01A1 with BlueNRG2. After googling around I found projects and codes for stm32 based nucleo boards, but couldn't find anything for BlueNRG2.
Can you provide me the project or source code for the same?
1 REPLY 1
alok
Not aware of any ready example available for BlueNRG2 with X-NUCLEO-NFC01A1.
However, if you have STEVAL-IDB008V2
https://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/communication-and-connectivity-solution-eval-boards/steval-idb008v2.html
You will notice there are Arduino UNO R3 compatible connectors are available. You can directly mount the X-NUCLEO-NFC01A1 on these connectors and re-use the sources available in "C" language available in X-CUBE-NFC1 here...
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-nfc1.html
Please choose a suitable project from BlueNRG-2 and integrate these code. Hope it helps
