Error : Command not found
Nandy K
Posted on March 03, 2016 at 09:34
Hai !
I am having two wifi modules and I have configured the initial settings.
In both the modules I am getting the status ''Handshake Complete''.
After this i tried to give command ''AT'' and both giving the response OK
now I have sent the command ''AT+S.SOCKD=8855'' only one module responds OK and the other now is showing ''ERROR: Command not found''.
Could you please help me why it is so?
Also tell me how to update the firmware through cable
3 REPLIES 3
Posted on March 03, 2016 at 13:35
''command not found'' means the module contains an old FW version (use FW3.5 on both of them), or provided command was not properly formatted (check string).
About the UART update, take a look at the hands-on manual.
Nandy K
Posted on March 03, 2016 at 15:10
Hi
Thank you  I have updated the firmware V 3.4 but could you please tell me where i can find the latest firmware version.
I searched on the ST website but couldn't find it :(
Posted on March 03, 2016 at 15:14
http://www.st.com/wifimodules
