2024-08-28 12:07 AM
Hi.
Please can someone tell me whether Part No: M24LR04E-RMN6T/2 (RFID Transponder) is able to communicate with MiFare Desfire ?
Application will be a custom designed PCB to be used as part of Prepaid payment system
2024-08-29 12:41 AM
How can I access the STMicroelectronics protocol ?
2024-08-29 01:53 AM
You can use firmware libraries like X-CUBE-NFC4.
2024-09-13 02:37 AM
Hi.
Please can you give the Part number for the testing hardware required for me to test Part No ST25DVxxK with your X-CUBE-NFC4 software.
I am referring to some kind of pre-assembled/configured test PCB where I can familiarise myself with your software before designing the my own PCB.
Thank you
2024-09-13 06:02 AM
Sure, e.g. the X-NUCLEO-NFC07A1.
But I have to correct a typo in my previous statement: I meant the ST25DVxxKC, the ST25DVxxK are already on NRND.
