VL6180X distance measurement through lens
Juan.2422
Can we use VL6180X to measure distance of an object through an optical medium (lens assembly). Can we achieve good accuracy?
Anne BIGOT
If you add a lens on the sensor, you will change the performances of it but also the class of the laser. This is not recommended by ST.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
