2024-11-09 04:29 AM
I'm using the VL43L4CX and with every measurement, I get the next range status:
2024-11-11 08:22 AM
That message is not an error - it's a warning.
In order to detect 'radar aliasing' we need two ranges with different pulse repetition rates. So we range in pairs - but we return the result of every range to you.
But for the first range, we don't have the other half, so we are warning you that the 'wrap check' ('radar aliasing') check has not been done.
And it happens for the first range after a start and never again - until the next stop/start sequence.
- john
2024-11-11 08:22 AM
- john
