2025-02-07 08:04 AM
We are moving to VL53L4CD.
Have it all coded but having a strange experience. Simplistically we use the sensor continuously and only use GetResult to retrieve the sensor readings (e.g. not CheckforDataReady).
So, simplistically looks sorta like this using the ULD:
VL53L4CD_SensorInit
VL53L4CD_SensorStartRanging()
while Forever
VL53L4CD_ResultsData_t result;
VL53L4CD_Error VL53L4CD_GetResult(&result);
This worked fine for the VL53L1X but for the VL53L4CD while all Init, StartRanging and GetResult are returning a status of 0 the reading never changes. It gets a reasonable reading first but then just never changes.
Any idea?
Thanks,
Will
2025-02-07 10:03 AM
Appears to have been the config
2025-02-07 10:03 AM
2025-02-10 07:53 AM
It almost always is the config - unless it's an I2C issue. Those are 90% of the bugs.
Nice work finding it. If you uncovered something someone else might run into, please share it.
- john
