VL53L1X status 9
BigOrangeFish
I can't find any information about status 9, how can I resolve this status?
1 REPLY 1
John E KVAM
That's because we hide the user manual.
When you download the driver from ST.com It's:
STSW-IMG009
VL53L1X ULD API (Ultra Lite Driver application programming interface)
Start with this one - it's probably closer to what you have.
There is also a full version. It is:
STSW-IMG007
VL53L1X full API (application programming interface and documentation)
The user manual is in with the code.
Anyway, a range status of 9 is 'signal failure'. Not enough photons were returned to get a valid range.
you can adjust this as you get to pick the minimum number of photons you determine is 'enough'.
Even if you don't use the ST driver. Download the code to get the user manual.
- john
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
