Time Of Flight calibration error (VL53L0X) with nRF52833
renanFazzani
Hi, I'm trying to use the VL53L0X sensor driver with zephyr and nRF52833, but I'm getting errors when the driver is trying to calibrate.
Below are the errors returned by the log system:
My question, how could I solve this, it seems to be a software problem right?
10 REPLIES 10
GHuan.2 -
Thanks! Exactly right. Before we finalize the name of the chip I do a lot of testing. And we changed the name of the chip from VL53L0 to VL53L0X. But, of course, I failed to use the correct directory when offering up that code.
I edited the post, covering up my faux pas.
- john
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
