Visitor II
July 12, 2024
VD55G1 camera driver (camera CMOS image sensors )
  • July 12, 2024
  • 1 reply
  • 1039 views
I want to use the VD55g1 camera on widows but i am not able to find the right driver
Best answer by MeganeG
The VD55G1, and all other BrightSense image sensors, can be used with the following evaluation software on windows: https://www.st.com/en/embedded-software/stsw-img501.html
Regards, Megane
1 reply
MeganeGBest answer
Regards, Megane
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
