Sensor intrinsics for VL53L8CH
wsun
I am working with the ST VL53L8CH sensor for research purposes. To generate a point cloud from depth measurements, I am trying to get the directional ray to each zone. I am wondering if there is a more detailed explanation of the configuration for SPAD maps in this diagram:
For example, in a similar sensor, the AMS TMF882X sensor datasheet has the following information for how SPADS map to each zone:
If not, is it reasonable to assume that the 16x16 zones uniformly make up the 45° x 45° square FoV, or is manual calibration with a known scene necessary?
John E KVAM
Go here:
VL53L5CX Multi-Zone Sensor get x,y,z of points rel... - STMicroelectronics Community
The VL53L5 and the L8 have the same FoV. So, the code in this post is identical to what you want.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
1 REPLY 1
John E KVAM
Go here:
- john
