2025-02-02 03:59 AM
I am using the VL53L8CX sensor on an I2C bus, and it operates normally until I run the i2cdetect command. After running i2cdetect, the sensor stops working properly, and calling vl53l8cx_check_data_ready() returns a GO2 error status.
Interestingly, if I have another sensor (e.g., a temperature sensor) enabled on the same I2C bus, the VL53L8CX recovers and continues working after i2cdetect. The temperature sensor is at a different address and only performs normal read operations.
Any insights or debugging tips would be greatly appreciated!
Thanks!
