How to use the driver parameter RangeMeanMilliMeter for VL53L3CX ranging?
Shadow77
Hello everyone,
    Recently I tried to use VL53L3CX to accomplish a distance calculating project. When referencing the document of VL53L3CX I found a little strange about the distance parameter.
    For example, the note of ranging capabilities table in the datasheet DS13204, shows that "The ranging distances reported are the ones reported by the driver by the parameter called RangeMilliMeter". While in the application note AN5561, it shows that "The ranging distances in the table below are those reported by the driver by the parameter called RangeMeanMilliMeter."
    What I confused is: inside the API(VL53L3CX_BareDriver_1.2.10), I could not find the driver parameter named "RangeMeanMilliMeter".While "RangeMilliMeter" could be found in the structure VL53L3_RangingMeasurementData_t. So if there has any difference between these two parameters? If yes, how to use the parameter RangeMilliMeter and what's its definition? Thanks.
John E KVAM
You found a bug in our documentation. They are the same. I will have someone remove the 'mean' from RangeMeanMilliMeter in the AN5561 document.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
- john
Get it. Thanks for your sincerely help!
