Unfortunately, you need to go through the address change methodology at every reboot.
Put all sensors in reset.
Bring one out and change it's address.
Then bring the next out of reset then change it's address to something else.
Repeat as often as required.
Unfortunately, there is no way to change the address permanently.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
