TESEO VIC3DA
ngodoanvan
How to know the TESEO VIC3DA module work correctly in designed board ?
Thank you very much
Francesco Virlinzi
Hi
1. You should have NMEA stream on the UART
2. in the $xxGSV you should have consistent data (to check RF-path)
3. the board should be strongly fixed to the car
4. after 10 minutes driving (time to calibrate) your VIC will be fully calibrated
Francesco Virlinzi
Hi
thank you very much
Announcement
