Teseo-LIV4F
Aravind
Hi Team,
          In this module(TESEO-LIV4f) can able to processing the data L5 band(NACIC data and IRNSS)
And how to update the firmware  for l5 band(navic and Irnss) and pls give refrence.
And any break out board avaliavle for this module(TESEO-LIV4F)?
Thanks and regards
ARavind.S.R
Hi
End of this years (early next year) there will available:
 - X-NUCLEO-LIV4A1 (arduino form-factor)
 - X-STM32MP-GNSS2 (raspberry form-factor)
 Francesco
6 REPLIES 6
Francesco Virlinzi
Hi
Teseo-LIV4F can support IRNSS (with other constellation) using a dedicated firmware (firmware available in the Teseo-LIV4FSW page). You can install it using the standard firmware upgrade procedure (or the teseo-suite).
End of the years or early next years two new prototyping board with Teseo-LIV4F will be available.
 Francesco
Aravind
Hi Francesco,
          In this module (Teseo-LIV3FL low power GNSS module evaluation board) can support Navic signal.
https://www.mouser.in/ProductDetail/STMicroelectronics/EVB-LIV3FL?qs=TuK3vfAjtkUQ7PYXAmUrgA%3D%3D
Thanks and Regards,
Aravind.SR
Hi
Sorry but all the LIV3 module family are L1-only GNSS, they can not acquire IRNSS because IRNSS sits on L5 signal.
At the moment Teseo-LIV4F is the only ST module able to acquire IRNSS
 Francesco
Hi Francesco,
Thank for your response!
Any evaluation board avaliable for this module(Teseo-LIV4F)?
Thanks and Regards,
Aravind
Hi
 Francesco
Future Electronics have this one that have the LIV4F
https://www.futureelectronics.com/future-development-boards/vespucci-evaluation-board
