2020-02-19 08:08 AM
I have Teseo-LIV3 micro on our first version of production board. The output is all zeros for position:
Samples of Data: (Has antenna attached)
$GPRMC,003948.000,V,0000.00000,N,00000.00000,E,0.0,0.0,071214,,,N*71
$GPGGA,003948.000,0000.00000,N,00000.00000,E,0,00,99.0,100.00,M,0.0,M,,*6A
$GPVTG,0.0,T,,M,0.0,N,0.0,K,N*02
$GNGSA,A,1,,,,,,,,,,,,,99.0,99.0,99.0*1E
$GPGLL,0000.00000,N,00000.00000,E,003948.000,V,N*47
$PSTMCPU,18.91,-1,49*4E
$GPRMC,003949.000,V,0000.00000,N,00000.00000,E,0.0,0.0,071214,,,N*70
$GPGGA,003949.000,0000.00000,N,00000.00000,E,0,00,99.0,100.00,M,0.0,M,,*6B
$GPGLL,0000.00000,N,00000.00000,E,003949.000,V,N*46
$PSTMCPU,25.97,-1,49*46
I have a dev board without antenna, positions are ok.
Can anyone give me some suggestions?
Thank You,
David
2020-02-19 08:13 AM
Hi
has your board LNA+SAW?
Did you have a look to the layout suggestion in the LIV HW manual @ https://www.st.com/resource/en/user_manual/dm00399112.pdf?
Francesco
2020-02-19 08:21 AM
Thank you, Francesco.
David
2020-02-19 08:27 AM
Also check reporting in other fields, it says it doesn't have a fix, 0 N, 0 E are just default placeholders. See 'V' and 'N' flags
https://docs.novatel.com/OEM7/Content/Logs/GPGLL.htm#NMEAPositioningSystemModeIndicator
Suggests your RF section isn't functional.
